  3. How delete a routed Net completely
  • Replies 7
  • Views 22078
Hossein1357
Hossein1357 over 11 years ago
I want to delete a routed net completely. I have made appropriate options in find filter ON - Vias & Clines & Nets - and selected them in Delete Net Options as well. As depicted below net is selected whenever I click on it but it is not deleted. I receive below message:
No element found.
 Delete Net
drive.google.com/.../edit
I should add that if I deselect Nets item it works only for every pin.
Thanks in advance,
Hossein
  • steve
    steve over 11 years ago
     Try making sure that Ripup etch is checked as well in the Options menu.
  • Hossein1357
    I have tried it. However, nothing has happend. I only receive that massage.
  • steve
    This looks like you have used the Route - Create Fanout command which stops you from deleting the entire net. To remove them try deselecting nets then drawing a window around the area which will remove the fanouts...
  • Hossein1357
    Yes, I have created them that way. However, selecting an area causes also other via/clines being selected, doesn't it?
  • steve
     Sorry - just realised what you want. In the Options menu make sure that Symbol etch is checked then in the Find filter you can enable nets and get what you need.
