  3. Need help on select entire net
  • Views 17651
sgilbert
sgilbert over 11 years ago
 Hi All,
I made a fairly larger schematic in ORCAD 16.6 (Around 50 pages). The Vcc power net is going to as many as 30 pages. When I am going for "selcect entire net", the nets in the same page were highlighted. But I want to know all the pages where the selected net is present. How can I do that. SImply I want to highlight the nets in all pages. Your help is highly appreciated.
  • steve
    steve over 11 years ago
     RMB - Select entire net is restricted to only work on that specific page. If you want to find the net across the whole design try seelcting the filename.dsn in the project window then in a page select the net you want to find and use RMB - Signals. You'll see a GUI fold out that have all instances of that netname, you can select each one and step through the design.
