  3. How to change the order of schematic pager
  • Replies 9
  • Subscribers 166
  • Views 25132
sgilbert
sgilbert over 11 years ago
I have a 10 schematic pages in my design. I want to change the order of them (re sequence). For example the 5th page should go to 7th place etc. Help me how to do it.
Gilbert
  • chads108
    chads108 over 11 years ago
    Which software package are you using?
    Chad
  • Hossein1357
    Hossein1357 over 11 years ago
    I have a similar problem. I am using 16.6 and I have added two sheets and placed some part of my design in them. Then I used off-page connectors to connect nets. I don't see the total page counts and page numbers in title block of new schematic pages?!. Do I have to set them by myself? Or, there is a way that I can update these numbers for every page title block?
  • sgilbert
     I am using Orcad 16.6 for the schematic.
  • VincentS
    VincentS over 11 years ago
    This is how I do it in Flat designs :
  • VincentS
    Depending on how your title blocks are set up you will have to edit them on each page
