  3. New pin number found instead of Old one!.
  • Views 17025
Hossein1357
Hossein1357 over 11 years ago
I see a strange behavior in Allegro PCB 16.6. I swap a location - D17 pin in SP6 FGG484 package with AA2 - in Allegro PCB and apply back annotation. Then I want to find the D17 pin in schematic and surprisingly I find new pin number - here AA2 in our example - instead of what I looked for - D17 - and I can't find D17 any longer in schematic? Below picture depicts actually what I find in my search. Click on the picture to see it completely. Can anybody please help?!.
Hossein
  • Hossein1357
    I wish if anyone could help me on this issue.
  • steve
    steve over 11 years ago
     If you make pin swaps in Allegro and back annotate the pins are physically moved on the schematic symbol so if you swapped D17 with AA2 then AA2 will be where D17 was and vice versa. Is it on another section of the symbol?. It won't disappear but it with move to the swapped location.
  • Hossein1357
    Yes, they are in two seperate parts of my symbol. I searched for both pins and found out that D17 is located in AA2 location.
  • Hossein1357
    Sometimes I see error messages in different stages of updating Schematic from PCB.
    1- I see below message in Allegro PCB when I want to export logic to Back Annotate Schematic:
    Error: Can't find destination directory 'D:/OrcadProject/REV5/SSPAV05_03/Net'.
    However, I select the Net folder again and run it successfully.
    2- When I want to Back Annotate schematic I see below errors in session log:
    ERROR(ORDBDLL-1108): No physical object present to attach property to.
       N6731110:  NET_PHYSICAL_TYPE   Part or Net stuff attempted, but failed
       N6731110:  NET_SPACING_TYPE   Part or Net stuff attempted, but failed
       N6730690:  NET_PHYSICAL_TYPE   Part or Net stuff attempted, but failed
       N6730690:  NET_SPACING_TYPE   Part or Net stuff attempted, but failed
    3- I have two pins which I created a NetClass for them in PCB. Sometimes when I try to Back Annotate schematic I see this message in swap file:
    .Section2 UpdateProperties Nets UppercaseCombined
    "{Net Name}"    "NET_PHYSICAL_TYPE"    "NET_SPACING_TYPE"
    "N6731110"    "MECH&PROBE"    "MECH&PROBE"
    "N6730690"    "MECH&PROBE"    "MECH&PROBE"
    .End
    How come that after create netlist it removes these two special net from their NetClass?
  • Hossein1357
    I made back annotate after swaping some pins in PCB and exported it to Schematic. Now, if I do create netlist and open PCB from Schematic, I will see below error messages:
    #1 ERROR(ORCAP-36036): Multiple pin Y3's which have different nets connected for U22: SCHEMATIC1, 08-FPGA IO0 (22.86, 73.66).
    Check for incorrect packaging of all devices in U22.
    #2 ERROR(ORCAP-36036): Multiple pin Y2's which have different nets connected for U22: SCHEMATIC1, 08-FPGA IO0 (162.56, 12.70).
    #3 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
    As far as I remember, I just swapped (Y2, Y3) with (A13, C13) !. when I looked at it further, I realized that these two pins were first unused pins in another schematic page. Now, if I look for Y2/A13 or Y3/C13 I see just one location in sheet and that's New pins(Y, Y3)!..
    How could this be happen?!. I am confused. What shall I do?
    Hossein
