  3. How to hide the Pin name of the components in Allegro PCB...
  • Views 18841
How to hide the Pin name of the components in Allegro PCB editor
sgilbert
sgilbert over 11 years ago
I am using cadence 16.6 for my layout. When I am placing the components on the board, the pin numbers are visible and it is annoying me. Please inform me how I can make the pin numbers invisible on the PCB editor.
Gilbert
  • Dhamodharann
    Dhamodharann over 11 years ago
    Hi Gilbert.. For your problem go to options-----> Package Geometry---->Pin Number option make it uncheck. Then your pin numbers will be get not displayed. Thanks & Regards Dhamodharan
  • sgilbert
     Dhamodharan,
    Can you please explain in little detail. I am not seeing any option in PCB editor. Please tell me how to go to "Options -----> Package Geometry---->". Is it in package editor ?
    Pls, help me.
    Gilbert
  • Dhamodharann
    Hi Gilbert ...
    Now currently whether you using the OrCAD PCB editor 16.5, 16.6 versions, all are same.In the editor window goto-----> color dialog(crtrl+F5)---->Package Geometry---->enable the pin numbers with different color and the option  get enabled.After that you do  the below option.
    Open the OrCAD/ Allegro PCB Editor. In right hand side of the editor window, find, options visibility three windows will get enabled. In case if it not get enabled means goto----->view----> window----> enable the options pane what eve you needed. In that option Package Geometry---->Pin number will be get enabled.
    In case if not enabled means contact the software vendor or reinstall the OrCAD software again.
    Thanks& Regards
    Dhamodharan
  • sgilbert
     Hi Dhamodharan,
    Thanks for making me understand clearly through your detailed explaination. I understood and I was able to do that. Thanks a ton.
    Gilbert
