  3. DRC error
  • Views 20599
DRC error
HoRangHam
HoRangHam over 11 years ago
I run DRC check on 1 of my design and getting an error
"ERROR:  [DRC0004]  Possible pin type conflict U4,VCC Power Connected to Output
SCHEMATIC1, P02 BUFFER CONTROLLER  (11.80, 2.20) "
And here how it connect in the schematic
I didn't get this error before. I just got it now after I edit the part in my library. What I edit was changed the pin type from "passive" to "Power"
How do I fix this problem?
Thank you
  • oldmouldy
    oldmouldy over 11 years ago
    Your VCC pin is not an output type, Power or Passive or Input types would not have the DRC generated for them. Tracking the pin types from the datasheet is usually a pretty reliable approach, this is listed as Power Supply Input on the datasheet for the part so Power or Input would be a good choice for the Pin Type.
  • HoRangHam
    Like I said I have this problem when I changed from "Passive" to "Power" I didn't set it to "Output"
  • Dhamodharann
    Dhamodharann over 11 years ago
    Try to edit the footprint and check pin options. The VCC must be passive pin. Then only it connected to the power connection directly. Thanks & regards Dhamodharan
