  3. How to insert a text string or company logo
  • Views 15285
Hossein1357
Hossein1357 over 11 years ago
I have some notes that I want to insert as Fabrication Notes in my PCB but I don't know how to insert a text string in it. Additionally, I am curious to know if there is a way to import company logo in Allegro PCB.
Thanks in advance,
Hossein
  • steve
    steve over 11 years ago
     Yes and Yes. Use Add Text then set class / suclass and text block size (as you would normally) and then pick a start point. Now right click Read from File and then browse to the filename.txt. The text will be imported. Make sure that the text you bring in has no special characters otherwise the text imported will only be as far as that charcater. For logos search this forum for a really cool tool called Logomaker. It's great for importing logos.
  • Hossein1357
    Thank you so much. I don't see why some features are so hard to find in Allegro PCB?!.
  • Dhamodharann
    Dhamodharann over 11 years ago
    Me too also facing same problem while installing.
