  3. At Allegro constraint manager nets are not enabled?
  • Subscribers 162
  • Views 15295
Dhamodharann
Dhamodharann over 11 years ago
After the component placement, when i try to put routing, on constraint manager the nets are been not get enabled. Default the 24V net is get enabled on all the all parameters. I had tried to set the constraint modes in the PCB editor at setup----->constraints------> modes.But still facing the problem. But me need to set the different values for different nets. Thanks & Regards Dhamodharan.
  • chads108
    chads108 over 11 years ago
    Click on the "+" next to Test 5 on the picture you posted.
    Chad
  • chads108
    Chad
