  3. getting problems after Pspice model is made from txt.
  • Views 15263
Bilalahm
Bilalahm over 11 years ago
Hi, i need to make a Pspice part for simulation. the Maker company only gives this data.
*Jun 01, 2010 *Doc. ID: 90412, Rev. A *File Name: part irfl9014_PS.txt and part irfl9014_PS.spi *This document is intended as a SPICE modeling guideline and does not *constitute a commercial product data sheet. Designers should refer to the *appropriate data sheet of the same number for guaranteed specification *limits. .SUBCKT irfl9014 1 2 3 ************************************** * Model Generated by MODPEX * *Copyright(c) Symmetry Design Systems* * All Rights Reserved * * UNPUBLISHED LICENSED SOFTWARE * * Contains Proprietary Information * * Which is The Property of * * SYMMETRY OR ITS LICENSORS * *Commercial Use or Resale Restricted * * by Symmetry License Agreement * ************************************** * Model generated on Oct 22, 96 * MODEL FORMAT: SPICE3 * Symmetry POWER MOS Model (Version 1.0) * External Node Designations * Node 1 -> Drain * Node 2 -> Gate * Node 3 -> Source M1 9 7 8 8 MM L=100u W=100u * Default values used in MM: * The voltage-dependent capacitances are * not included. Other default values are: * RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0 .MODEL MM PMOS LEVEL=1 IS=1e-32 +VTO=-3.87971 LAMBDA=0.0503704 KP=0.713612 +CGSO=2.47152e-06 CGDO=1e-11 RS 8 3 0.116837 D1 1 3 MD .MODEL MD D IS=5e-21 RS=0.15039 N=1.5 BV=60 +IBV=10 EG=1.2 XTI=4 TT=1e-07 +CJO=4.40194e-10 VJ=1.63887 M=0.440757 FC=0.5 RDS 3 1 600000 RD 9 1 0.0001 RG 2 7 9.4415 D2 5 4 MD1 * Default values used in MD1: * RS=0 EG=1.11 XTI=3.0 TT=0 * BV=infinite IBV=1mA .MODEL MD1 D IS=1e-32 N=50 +CJO=1.96085e-10 VJ=0.665506 M=0.480463 FC=1e-08 D3 5 0 MD2 * Default values used in MD2: * EG=1.11 XTI=3.0 TT=0 CJO=0 * BV=infinite IBV=1mA .MODEL MD2 D IS=1e-10 N=0.4 RS=3.00002e-06 RL 5 10 1 FI2 7 9 VFI2 -1 VFI2 4 0 0 EV16 10 0 9 7 1 CAP 11 10 6.62636e-10 FI1 7 9 VFI1 -1 VFI1 11 6 0 RCAP 6 10 1 D4 6 0 MD3 * Default values used in MD3: * EG=1.11 XTI=3.0 TT=0 CJO=0 * RS=0 BV=infinite IBV=1mA .MODEL MD3 D IS=1e-10 N=0.4 .ENDS irfl9014
I made a model by model editor.
getting errors. like
INFO(ORPSIM-15423): Unable to find index file irfl9014.ind for library file irfl9014.lib.
INFO(ORPSIM-15422): Making new index file irfl9014.ind for library file irfl9014.lib.
Index has 0 entries from 1 file(s).
ERROR(ORPSIM-15108): Subcircuit IRFL9014 used by X_M1 is undefined
  • oldmouldy
    oldmouldy over 11 years ago
    Check that you have maintained the "line edited" format of the original model, SPICE, and therefore PSpice, relies upon the character positions to correctly interpret the model text, for example, the "." of ".SUBCKT" must be in the first character position on a line. There is also a comment about SPICE3 format, there are some subtle differences between the SPICE formats which may cause issues, notably SPICE3 allows "*" to represent a comment at "any" character position on the line, SPICE2 (and PSpice) only allows a "*" at first position on the line, otherwise it gets interpreted as "multiply", ";" is allowed at "any" position for a comment in SPICE2 (and PSpice)
  • oldmouldy
