  3. How to automatically replace reference designators on P...
  • Replies 7
  • Subscribers 168
  • Views 15845
How to automatically replace reference designators on PCB
miniol
miniol over 11 years ago
Is there possible to place automatically reference designators on the PCB (Allegro 16.6)? I mean the function similar to i.e. Altium that can automatically replace designators in the predefined order and orientation. I need to generate an assembly drawing for my PCB which has around 900 components on both sides, and I don't want to replace manually each of the reference designator text.
  • steve
    steve over 11 years ago
    Try Logic Auto Assign RefDes then click on More for the Options. This will rename the refdes based on left-right, top-bottom etc.
  • miniol
    This is not what I wanted to do. I don't want to change designators name. I only want to tidy up designators to make them look more readable on the assembly drawing (place them in the same direction and avoid overlaying).
  • Poppy
    Poppy over 11 years ago
    dalTools has a few commands to do that. You can download the tool for 30 days are try it out at daltools.com
  • Poppy
    dalTools has some commands that do this quite well. you can download the tool for a 30 day free trial at daltools.com
  • Dhamodharann
    Dhamodharann over 10 years ago
    For that you have to arrange the each text separately one by one.
