  3. Plotting .brd file the error occurs?
  • Views 13295
Dhamodharann
Dhamodharann over 11 years ago
Hi..
I had created the small PCB with the 40 x 50 mm. When i am try to place it with the page outline (asizeh), that  time i try to plot it means, the error occurs. any help of this problem My error is attached below..
Thanks in advance for the help.....
  • oldmouldy
    oldmouldy over 11 years ago
    You could try a Tools>Database Check and see if the database is OK; there could be an issue with the printer driver, so check that is up to date; remove the allegro.ini from the "pcbenv" folder with PCB Editor closed in case there is an invalid printer in the list, then the start PCB Editor and try printing again, you will need to run through the Plot Setup to get the settings back.
