  3. Dynamic filled Planes go solid after a Constraints Manager...
  • Views 21661
Dynamic filled Planes go solid after a Constraints Manager change
Korey
Korey over 12 years ago
I have a 4 layer board with a power plane and ground plane. The xSection is setup as a "Positive" plane for both and connections to the power and grounds is correct and I have no DRC errors. I'm using OrCAD PCB Designer 16.6 with the latest patches or close (SP032). I've found that if I go into the Constraints Manager and change a property (i.e. Trace width, or a separation constraint etc. ) the dynamic filled planes go solid and of course then get DRC errors. I have to overcome this by going to the XSection and change to "Negitive" plane for power and ground and then Apply that change and then change back to a "Positive" plane and then the Ground and Power connections and etching is then correct. I've played with the Global Dynamic Parameters under <Shape> but still have the same problem. If someone can shed light on this issue, I would greatly appreciate your input. Seems like a bug in the tool but maybe I'm missing some setting.
Thanks.
KC
  • SevenFortyOneB
    SevenFortyOneB over 12 years ago
    This is common behavior (at least in my experience). After you make changes in CM, you need to "refresh" the shapes by going to Display->Status and then click the "update to smooth" button. This should restore your shapes to normal.
  • Tolly
    Tolly over 4 years ago in reply to SevenFortyOneB
    7 years later, this problem is not yet solved. They have changed de menu, instead.
    Menu path for version 17.4 (diffferent menu and one level deeper):
    Check -> Design Status -> Shapes -> Update All
    Next versions it will probably be different and even more hidden (instead of fixing the bug, it's crazy)
