  3. Changing net on vias
  • Replies 17
  • Subscribers 167
  • Views 24256
RobBlomstrom1
RobBlomstrom1 over 11 years ago
Besides the traditional way to replace a via or reroute to it, does anyone know of a workaround or skill script to "assign" a net to a via much like we do with shapes?
  • chads108
    chads108 over 11 years ago
    I have one I use for this.  Would have attached if I could figure out how to do it.
    Chad
  • oldmouldy
    oldmouldy over 11 years ago
    There is one in the installation at share\pcb\examples\skill\cmds, change_net_on_vias.il but the ability to attach files to the forum does seem to be absent now, use rich formatting will allow "media insert" from computer upload but no idea if that would then be available to download!
  • eDave
    eDave over 11 years ago
    DE_changeViaNet_public.zip
    See attached (if it came through - I just dragged and dropped
    Place the file: "DE_changeViaNet_public.cxt" in your Skill path
    In your allegro.ilinit file add the following lines:
    loadContext("DE_changeViaNet_public.cxt")
    axlCmdRegister("chgvianet" 'CVN_changeViaNet ?cmdType "interactive")
    Type "chgvianet" in the console window to run the utility. Use the Right Mouse Button for options.
  • chads108
    Rob,
    I would use Dave's SKILL script if you are just wanting to change nets on vias.  It is a bit less complicated to use than the one I sent you offline.
    Chad
  • ALBERTO CAVA
    ALBERTO CAVA over 8 years ago
    Hello Dave
    Im using this skill, I really like it a lot, thank you for sharing! After I change some vias to a new net I need to right click and the select done on the menu to finish the command, if I click F6 (done) it doesnt works, is this a bug related to a hotfix? is there a way to use F6 also as done?
    Thank you
    Alberto
