  3. Component not transferred from capture to pcb editor
  • Views 15104
nuldum
nuldum over 11 years ago
I have tried now for days to transfer my design in Orcad Capture CIS to PCB Editor, but no matter what I do one of my components is not transferred to PCB Editor. The component is a transformer with a custom footprint. I've made a lot of custom components and they all transfer just fine except for this one component.
I can see it on the design cache, but it doesn't show up on the Bill of Materials, it's not in part manager and it doesn't get transferred when creating a netlist. What could I possibly do wrong when it worked for every single other component I made myself?
I'm using a custom database it it works smoothly with the other components.
- Nikolaj
  • oldmouldy
    oldmouldy over 11 years ago
    Check the Primitive property value for the component. The Primitive value should be set to Default or Yes to work as a regular component, a Primitive value of No can get the behaviour that you are seeing.
  • nuldum
    Thank you for you answer. The Primitive property is already set to default and changing it to YES does not seems to change anything.
  • redwire
    redwire over 11 years ago
    Try manually placing the transformer on the board. You will get a warning in the command window if a padstack or shape is missing. Much harder to track this down for beginners if it is during netlisting from OrCAD.
