  3. Searching for reference designators using wildcards in OrCAD...
  • Views 17813
Searching for reference designators using wildcards in OrCAD Capture
Allan M
Allan M over 11 years ago
In OrCAD Capture, I cannot figure out how to search for certain components in my schematic such as resistors.  For example, I put the following string in the search field, "R*".  When I click the search button (the binoculars), I get all kinds of elements I don't want, such as other components, pins, nets etc.  The desired result is that only resistors are highlighted.  I tried turning off all the check marks in the search customization menu except for "parts" but I still get elements I don't want.  I tried using the string "REFERENCE=R*" and checking the Property Name=Value menu option but that just yields nothing.
I want to be able to highlight and then edit only resistors (or capacitors if I search for "C*", etc).  Does anyone know what I am doing wrong?  Thanks in advance.
Allan
  • oldmouldy
    oldmouldy over 11 years ago
    Searching for r* with Parts is going to get "any" Part with a property that starts with R which is likely not what you want. Set the Search Options for Highlight, Property Name=Value and Parts, set the search string for reference=r* and left-click on the 'binos', seems to work fine for me. This function may well have been tweaked since the original 16.6 release so check that you are running a recent hotfix.
  • Allan M
    Hi oldmouldy, I must have been having finger trouble because it is working fine now! I did not look for any hotfixes althouth I will when I get a chance. Thanks for the help!
  • tennywhy
    tennywhy over 6 years ago in reply to oldmouldy
    how can set a part reference location? it not work whatever i do ?
