  3. Logomaker command error occurs?
  • Subscribers 162
  • Views 15065
Dhamodharann
Dhamodharann over 11 years ago
Hi..
I had followed the instructions of  Dave's procedure. When i am try to load command error occurs, i will attach ILINT file,note me that  where i have to insert the command of the
                                  load("logoMaker_public.il").
I had  Installed potrace-1.9.win32 and ImageMagick-6.7.0-10 ,but it showing in command line as
Command > logomaker
E- *Error* _gets: argument #1 should be an I/O port (type template = "p") - nil
Command >
pls let know details. I don't know what mistake done by me.Any help please.
  • eDave
    eDave over 11 years ago
    Do you have the latest hotfix and the latest version of the code?
    LogoMaker appears to have installed OK but is not able to load the form.
    Creating the form requires write access to your Windows TEMP folder (defined by your environment variables).
  • Dhamodharann
     Kindly thank you for your reply.
    Yeah...dave now currently using the  OrCAD 16.6-with hotfix 16.6.034. For past week i spend lot of time to install, but finally errors occurred.
     Whether i had done any mistake on loading .il file.  Where do i insert the command   load("logoMaker_public_il").
    Then how do i insert the step  "Creating the form requires write access to your Windows TEMP folder (defined by your environment variables)."
    How can i do above step?  I don't know what mistake done by me, any solution for this problem?
