  3. Convert Orcad Capture to Design Entry HDL
  • Replies 7
  • Subscribers 167
  • Views 20133
eANIL
eANIL over 11 years ago
It is so disappointing that we dont have Cadence supported Translator with in our own Cadence tools, I would like to translate Orcad capture schematic to DEHDL flow, I used cap2cond.exe to do the same, still this is not working and stopped in middle. It is not actually creating pc.db, and this method is not supported my cadence! argh... Could anybody suggest a better method of translating capture to DEHDL
  • tallmanu
    tallmanu over 8 years ago
    Hi Anil,
    I have the Cap2Cond utility. Can you give me the steps to convert. Also is there some way I can maintain the same ref des as in Orcad schematics. This is to check for the correctness in the conversion process.
  • tallmanu
    Hi Anil,
    I have the Cap2Cond utility. Can you give me the steps to convert. Also is there some way I can maintain the same ref des as in Orcad schematics. This is to check for the correctness in the conversion process. - See more at: community.cadence.com/.../1349404
