  3. Netlist Aborting in allegro PCB editor 16.5
  • Views 21860
shreeja
shreeja over 11 years ago
Hi guys,
               I got the following error while netlisting a design. i dont know what is the problem, if anybody knows or experienced on this error, pls help me to solve.
#1 ERROR(ORCAP-36052): Value for property PCB Footprint contains carriage return for CAN.
#2 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
Srimathi
  • steve
    steve over 11 years ago
    I think you have a carriage return in the PCB Footprint property for the part. Delete what's there and retype it so it just says the PCB Footprint name.
  • Dhamodharann
    Dhamodharann over 11 years ago
    Try to check footprint properties and update the netlist. The carriage return must be the property defined in footprint.
  • jayesh1808
    jayesh1808 over 9 years ago
    If footprint contains " .  " or / type of special character or name of footprint in .dra file is not same than this type of error occur also if one footprint name is in small and other (in orcad design file ) is capitol this also create a problem so keep all the file name  exact same
