  3. How to compare two Schematic Capture Projects
  • Views 18448
Hossein1357
Hossein1357 over 11 years ago
Hi all,
I am using OrCAD 16.6. I have two designs that I can't track the changes between them. I am wondering if there is a way to compare and find differences between these two designs? Afterwards, I am going to do the same for their PCB design files - .brd files -
Comments are welcome
Hossein
  • steve
    steve over 11 years ago
    Look in the marketplace, there's a free app for design compare. http://www.orcadmarketplace.com/portals/0/easygalleryimages/540/videogallery2/thumbs/ProductDetails/tabid/93/ProductID/45/Default.aspx. For PCB Design compare look under Tools - Design Compare which will compare two xml files. You can create these on import of the netlist.
  • Hossein1357
    From where can I find Coupon Code?
    I can't go ahead without entering it!.
  • steve
    You should have received an email with that information on.
