  3. BNC Schematic Symbol (2 pins) to PCB Footprint (5 pins)...
  • Views 20267
BNC Schematic Symbol (2 pins) to PCB Footprint (5 pins) best practice
cadSmith
cadSmith over 10 years ago
Hello Everyone,
I have a BNC connector that physically has 5 pins.  A typical BNC schematic symbol only has two pins.  In the past I've simply made a new schematic  symbol with 5 pins, four of which are ground, and called it a day (schematic symbol pin count matches pcb footprint).
Has anyone figured out how to use a 2 pin schematic symbol for the 5 pin part?  I'd like to clean up future schematic and avoid having the extra pins.
I typically shy away from having a schematic symbol pin count differ from the footprint but am willing to make an exception in this case.
Would you leave it as a 5 pin schematic symbol and call it a day?  Would you "clean" it up and somehow make the BNC connector have 2 pins in the schematic?  If so how?
BNC_2pin, BNC_5pin, BNC_part
Thanks for any inputs.
  • chads108
    chads108 over 10 years ago
    That can be done with the PACK_SHORT property.  Here is the link to a demo if you have a SourceLink account.
    http://support.cadence.com/wps/myportal/cos/COSHome/viewsolution/!ut/p/a1/hY_PboJAEIefpQ9gZhaQHY6bphGFSKyaulyaQRYlumD40-d34eKp7dx-k2--mYEcTpA3_FNfeKjbhu9TzsPvtfgIRJzhZhWpd1Qod5tjIrxELh2gHYC_lML_5r8gn5E_DNqtkC8HpWmEapWEn7E8-JhJODZtZ92x-8lVGvNI6-YGeuhGM3V6w935GnN_BS35XFFQVBR5opQFUlX4JRELzwUOeObb-zi9vx1tYTrQQkgKlx7Bw55woS35Vr09AS3wcaI!/dl5/d5/L2dBISEvZ0FBIS9nQSEh/
  • cadSmith
    Thanks for the reply.  Unfortunately the link gives a 404.  Could you please repost.
    I also searched for pack short in the forums, based on your comment,  and came up on the following answer which worked for me.
