  3. Is there any option to assign net manually
  • Subscribers 163
  • Views 15233
Srimathi
Srimathi over 11 years ago
HI all,
        Is there any option to assign net for vias and components by manually in orcad pcb editor 16.5.
Srimathi
  • Dhamodharann
    Dhamodharann over 11 years ago
    In my point of view, It's not possible in cadence.
  • steve
    steve over 11 years ago
    There is a skill file that will allow you to change the net of a via. Look at <your_install_dir>\share\pcb\examples\skill\cmds called change_net_on_vias.il but this will only change the net of a via. You can assign nets/ components if you have an Allegro PCB Designer license BUT the recommended flow is to do the logic in a schematic (Capture / DE-HDL) and import the netlist into the PCB
