  3. Outline width can be increased directly in PCB editor?
  • Views 13979
Dhamodharann
Dhamodharann over 10 years ago
Can i directly change the width of the board outline?
  • steve
    steve over 10 years ago
    If it's drawn with "lines" then use Edit - Change then set the width in the Options window and then window select the items you wish to change. If it's drawn with a Rectangle then no.
  • Dhamodharann
    I had created with setup---> outline----> Board Outline an rectangle is drawn . Whether it is possible in this option.
  • steve
    Well based on my previous comment that's a Rectangle so no. Either decompose the rectangle and then set a width or simply set the undefined line width in the artwork control form......
