  3. DXF file exporting PCB editor makes board outline invisible...
  • Subscribers 163
  • Views 15240
DXF file exporting PCB editor makes board outline invisible?
Dhamodharann
Dhamodharann over 11 years ago
For exporting the DXF file from .brd file, the board outline is not get enabled in the auto cad drawing. Simply i had put the line for the board outline and then exported to DXF.
After exporting, board outline is not get enabled, components are only get enabled.  How to view the board outline in CAD drawing?
The image link is attached    http://s28.postimg.org/a2wcnzqnh/Error_Message_47.png .
While exporting to DXF file, Board outline, drill, 0 layer,OBS SSTOP, OBS SSBOT layers need to viewed in cad drawing. How to enable it while exporting.
  • steve
    steve over 11 years ago
    You simply need to have it displayed in the PCB Editor window for it to be included in the exported DXF file. A good way to check is to use File - Export - DXF, specify an output name then Edit the Layer Conversion File, when the GUI comes up check to make sure the outline is there, then check Select all and use layer name generated from class and subclass and then click on Map. This specifies the DXF layer names, then click OK and Export.
  • steve
