  3. Pour keepout
  • Views 15001
Pour keepout
Brian Rocks
Brian Rocks over 10 years ago
I would like to have a 100mil border around my board to keep out copper pours.  It will be mounted in metal rails so I don't want the possibility of a short.
It is a square board that I used a rectangle to define the board outline.  So I used z-copy to offset the border in 100mil.  Now I would use change to change the class to... what?  Would it be BOUNDARY:ALL?
  • Brian Rocks
    Apparently : E- (SPMHGE-543): Changing rectangle to a different class is not supported. Do I need to redraw the outline using lines then?
  • chads108
    chads108 over 10 years ago
    If you want to keep copper out on all layers, you should have changed the z-copy layer to the Route Keepin / All layer.  If it is only for certain layers, you might want to create a shape on the Route Keepout layer for the particular layers desired.
