  3. Can cadence do the Derating checks?
  • Subscribers 163
  • Views 15415
xiaoyi594
xiaoyi594 over 11 years ago
Hi , I am doing the derating checks for our schematics, manually, one by one, this is laborious...
Generally, derating should be considered during design process when choosing the component, but for some reason, we are required to check all the components' derating status before final release of schematics.
Does Cadence have this kind of function?Could I write some custom scripts to do so?Even if just resistors and capacitors could be automatically checked by software, it will still save us a lot of time...
Thanks!
  • xiaoyi594
    Anyone konws this? thanks.
  • Alok Tripathi
    Alok Tripathi over 11 years ago
    Yes. You can use PSpice Smoke Analysis to get this done. It will check the deration of devices based on circuit operating conditions (applied voltage, current etc ) and one can also define and apply custom deration on one of more devices in the circuit. You can find more details in PSpice Advance Analysis user guide on this topic.
    Here are some references from web
