  3. Silkscreen top text not viewed in GC prevue?
  • Views 13360
Dhamodharann
Dhamodharann over 10 years ago
I had created the artwork generation, Then i had tried to import the artwork on GC prevue tool. When i try to import SST layer, text are not visible,same time i view texts enabled in Allegro PCB editor.
I didn't mirror SST layer. I had tried to view on the View mate tool also. The same problem occurred ?
  • oldmouldy
    oldmouldy over 10 years ago
    Texts probably have a 0 photoplot width and will be drawn with a single pixel width in PCB Editor, and the 0 width won't be output to Gerber. You can change the photoplot width in the text block setup, or override the "Undefined Line Width" for the respective Film in the Artwork Film Control.
  • Dhamodharann
    Thanks  a lot. Now i am able to see the silkscreen top texts outlines in GC prevue tool.
