  3. Find trace by width
  • Subscribers 166
  • Views 17271
Find trace by width
Brian Rocks
Brian Rocks over 10 years ago
I laid a few traces down that are of pretty thin thickness.  Is there a way to "Find" traces by their thickness so I can beef them up?  Or do they need to be done individually?
  • oldmouldy
    oldmouldy over 10 years ago
    You can select Clines / Cline Segs only in the Find tab, select the objects in the canvas with the mouse: Windows Select, shift / control and left-click on objects to refine the selection, hover over any member of the selection set and right-click>Change Width and specify the width. To set "everything" to a given width, Edit>Change, set only Clines and Cline Segs in the Find tab, check the box for Line Width in the Options and specify the width, window select the board, the width will be changed, or flagged as "already that width", then right-click>Done to accept what you see (Cancel to change the Options and select again or Oops to quit the change command and not make any change)
  • PCBT
    PCBT over 9 years ago
    cline change width
    The cline change width command allows you to increase or decrease the width of specified routing cline segments. The tool creates a new vertex at the location of the width change. The tool does not check for DRCs during the width change operation, but does report any new violations as online DRC markers.
    This command does not apply to non-conductor (geometry) lines, bond wires, and so on.
    "Filter by cline width (Minimum & Maximum)" allows you to choose only the needed width to change.
