  3. Using scriptpath
  • Replies 11
  • Views 19261
Using scriptpath
aricbeaver
aricbeaver over 11 years ago
Before updating to 16.6, the "Setup > User Preferences > Paths > Config > scriptpath" seemed to work fine when using "File > Script... > Library... > 'select file' > Replay". Now the file still shows up in the "Library..." list via the "scriptpath" configuration but when "Replay" is clicked the following error occurs:
"E - File does not exist: <filename>"
Why is this? The file is most definitely exists in the "scriptpath".
Aric
  • kabalee
    kabalee over 11 years ago
    Hi , i thing you did not set the path correctly please assign the path in C drive .keep you script file in this below path C:\Cadence\SPB_16.6\share\pcb\text\script
  • aricbeaver
    Thanks for your reply, kabalee.
    We have a custom path directory that is not linked to any specific version of Cadence so placing the file into that directory would not fix the issue. There is a custom path setup via "Setup > User Preferences > Paths > Config > scriptpath" and when clicking the "Library..." button the from the "File > Script..." menu the dialog will find the scripts in the "scriptpath" but upon replaying them PCB Editor prompts that the file does not exist.
  • aricbeaver
    Another thing to add: if you manually browse to the desired script file it will replay just fine, regardless of the "scriptpath" setup.
  • steve
    steve over 11 years ago
    What hotfix are you running because this works for me.... The latest is S042. Also are they a mapped network path or unc path ?
  • aricbeaver
    Hi steve,
    I just updated from S038 to S042 but that did not fix the issue. Also, the "scriptpath" is not a network path, it is local. I set the "scriptpath" to "C:\", "C:\Users\<username>\Desktop", etc. but the result is the same.
    Thanks for your help.
