  3. On IPC 2581 data transfer standard problem?
  • Subscribers 163
  • Views 14665
Dhamodharann
Dhamodharann over 11 years ago
Hi..
Just  recent days i had start to learn about  "IPC 2581- data transfer standard"  with some tutorial & IPC  website.I had read article by Jerry “GenPart” Grzenia in cadence forum, some doubts are raised during the exporting the file.
 I had tried export of the file in full design mode, in that layer mapping mode and film creation option tab provided. We want to use two tab options while exporting.
Whether i want any configuring of layer mapping edit & film creation  during the exporting the (.XML) file.
Can anyone help to understand options provided in the IPC 2581 format standard.
Thanks in advance for help.
  • steve
    steve over 11 years ago
    Look at <your_install_dir>\doc\algrologic\algrologic.pdf, page 124 onwards describes all you need to know about IPC2581. You can also get more info from www.ipc2581.com.
