  3. Change names of Subclasses/Layers?
  • Views 1172
thewill2live
thewill2live over 10 years ago
Hey guys, I've been looking around for a SKILL command that will allow me to rename a layer in the stackup (like you can visually from the stackup window). What I'm trying to script is the process of inserting a layer between two existing layers in an existing design and updating all the necessary portions of the file, namely that the layer names need to make sense. For instance if I add a new layer between Lay1 and Lay2 in the following stackup:
TOP
Lay1
Lay2
Lay3
BOT
I need it to now be:
TOP
Lay1
Lay2
Lay3
Lay4
BOT
Rather than:
TOP
Lay1
Lay4
Lay2
Lay3
BOT
Does anyone know of a way to get this to work?
