  3. Cadence TCL: How to get user input
  • Views 16729
Jason Stubbs
Jason Stubbs over 11 years ago
I would like to ask the user for a text input to use in my tcl script.
I have tried gets stdin, but the command window returns an error: channel "stdin" wasn't opened for reading.  How do I open the stdin channel?
Is it possible to launch a dialog window to prompt the user instead? Something like this:
  • oldmouldy
    oldmouldy over 11 years ago
    Tk is the easiest way, take a look at the capPdfLaunch.tcl source to see how this utility uses the grid layout to display a form and get the values from it to control the utility when the user accepts the form, you could take the form design and supporting activity handling directly from the utility to get started and testing, then dump anything unnecessary later once debugged. You could also take a look at the capCustomSamples\HTMLSamples to see how to get input from an HTML form, you would probably need to have a very good reason to use this over the Tk method since the "wiring up" is somewhat more involved due the interaction with the "local web server service" to render the form and get the "post"ed results.
  • Jason Stubbs
    OldMouldy,  thanks for the info.  I've been busy on project work for a couple of months. Finally getting a few free moments to look at this again.  I am an absolute beginner on the Cadence TCL stuff and I have to admit that I cannot understand how the capPdfLaunch.tcl source works! For the single variable user input that I need, I think the grid form is overly complex (for me to understand!).
    Is there a way to pass a variable through the command window? Either by setting a variable value before running the script or by passing it as a parameter?
    I can see that I am still a long way off from having this as an integrated part of our setup!
