  3. Command line arguments to start OrCAD Capture with different...
  • Views 18792
Command line arguments to start OrCAD Capture with different license options?
johe
johe over 11 years ago
Is there any command line arguments for capture.exe (capture.exe -xxxxx) to start OrCAD Capture with different license options?  Something similar to 'Allegro.exe - orcad' that can start Allegro PCB Editor with OrCAD PCB Designer license (with overrides the default set).
I know I can always use 'File'->'Change Product...' to switch between different licenses but I am just wondering if command line option is available?
Thank  you.
  • oldmouldy
    oldmouldy over 11 years ago
    The only command line option to start Capture (CIS) is "-i" to set the location of the Capture.ini file, you cannot set which license is used from the command line.
  • johe
    Thank you for reply. There is actually another argument option '-viewer' for read-only mode. But I guess you are right that there is no option to select another license/suite to start the Capture. It is not a big deal for me. Just a few more click. Anyway, thanks.
