  3. STEP file size
  • Subscribers 163
  • Views 18119
STEP file size
Wild
Wild over 11 years ago
What is the size limitation on a step file mechanical import?
Just got this error for the first time when tryingg to save an imported STEP model of a second board to my current board:
The facet file(.xml) for the STEP model "xxxxxxxx.stp" cannot be found or it's size is too big to be attached.
  • steve
    steve over 11 years ago
    This is related to the facet file size and not the size of the STEP model. Have a look in the stepfacetfiles4map directory and checkout the size of the xml file. If I remember correctly the limit is 4MB zipped. You may need to raise an enhancement request with cadence or the channel partner.
  • Wild
    Steve,
    The size of the xml file that did not work is 115MB
    The size of the file that did work is 44MB
    What I did was recreate the STEP model of the 3rd board with only a few components high lighted during the STEP model export.
    Many thanks.
