  3. Place Database Part prompting for SQL Login Repeatedly
  • Views 13923
dkman123
dkman123 over 10 years ago
I wrote a very detailed post in the PCB Forum (which may have been the wrong place).  It said it needed to be previewed by a moderator, but that forum doesn't list a moderator so I think it's in limbo.
I'm using OrCad 16.6 Lite in a Win 8.1 update 1 64bit VM.  I'm attaching to SQL Server 2012 on the host machine.  I have Access 64 bit in the VM attaching fine.  I have a 32 bit ODBC connection that tests fine (yes, I hit the error message trying to use the 64 bit ODBC first).
OrCad creates the DBC fine, it only prompts for the password once, sees all of the tables and fields, etc.  But when I try to place a part it keeps on prompting.
If I try a wrong password it knows that it's wrong.
If I hit the Options button and the database dropdown shows the other databases that the user has access to
I tried running as Administrator with the same results.  I deleted the Capture.ini and DBC file to recreate them as Administrator, no change.
I changed the SQL login's password in case symbols were messing it up, no change.
I wrote an Auto-it script to keep entering the password, but that didn't get me anywhere.
I imagine there's something easy that it causing this, but can't seem to find it.
  • bmcgeorge
    bmcgeorge over 10 years ago
    I have nearly the exact same environment.  Mine is Win 8.1, SQL 2008, OrCad 16.6 lite.  I'm experiencing the same problem.  Were you able to find a solution?
  • dkman123
    I have not so far. It did work when I set it up in the production environment (copied the SQL structure and data, then set up the DBC). Maybe the issue is that "Lite" won't talk to SQL. I don't know OrCad well enough to say. SQL was the part I was working on.
  • bmcgeorge
    That's exactly the problem. I confirmed it with EMA support. The "lite" version doesn't support SQL. The "lite" version only supports Access databases.
