  3. Cannot Place part manually in Orcad 16.6 Pcb editor
  • Replies 35
  • Subscribers 168
  • Views 35718
Deep7086
Deep7086 over 10 years ago
{NEW TO ORCAD]
I can netlist (with the usual renaming warnings) and open the netlist in Orcad PCB. I get a (correct) list of parts when I go to Place/Manually - but there's no Quickview preview and I can't place anything. I can check the parts but then when I hit ok Its just blank. There should be an error message to hint what's wrong - but I don't know where to look (netrev.lst is "clean" with no error/oversight/warning detected). Very, very frustrating!
After netlist i can see a new.brd file but its just waste. I cant place anything. Plz i need to get done with a project within 2 weeks and this thing is just eating me.
Any Instant help would be appreciated.
Deep.
  • Deep7086
    I tried loading previous drillf  file onto new empty board..it worked...but not this...
    ANyways I have sent the files to the manufacture... havent heard anything from them yet.
  • chads108
    chads108 over 10 years ago
    If you make only those layers visible in Allegro, is there anything on them?
  • Deep7086
    No idea. I am just waiting on my manufacturer.
    Is there any way I can add title block to my PCB board similar to one in Capture.
    And how to increase the spacing the traces and traces/pads.
  • Deep7086
    hey chad,
    I am not able to view silkscreen artwork. I dont know why. the filesize of slkscreen artwork  is 3kb
  • oldmouldy
    oldmouldy over 10 years ago
    "Title Blocks" are Format Symbols, there are some provided examples, Place>Manually, Advanced Settings, check the "Library" option then, back in Placement List, select Format Symbols from the drop-down to see which format symbols are available on your configured PSMPATH. For the Silkscreen, check that the "Undefined Line Width" has a value for the selected Silkscreen output film, otherwise, objects with a database width of 0 will be suppressed.
