  3. How to fix impedance mismatch?
  • Subscribers 163
  • Views 15028
Anonymous
Anonymous over 11 years ago
In constraint manager I set the value for impedance and make all nets close to certain tolerances.   Then I it auto route and have bunch of impedance mismatch DRCs
1)I thought its constraint driven tool, so it should have routed within the tolerance of impedance I specified.
2)How to fix impedance mismatch.  I try delay tuning, it didn't work. It just adds more delay.
  • oldmouldy
    oldmouldy over 11 years ago
    You need a High Speed option for the Autorouter to get it to support impedance, used to be called HP for the stand-alone router product, now part of PCB Router Option for Allegro PCB Designer, otherwise you will get the Min_Line_Width assigned to the net when autorouting.
  • oldmouldy
