  3. Dynamic Reconnect during move component.
  • Subscribers 168
  • Views 15161
GP studio
GP studio over 10 years ago
In PCB Designer Professional, when i move the symbols, the ratsnests are reconnected only after the symbol are placed. There is a way to reconnect the ratnests to the near points but during move symbols ?
Thanks for any answer to this question, Gianni.
  • steve
    steve over 10 years ago
    Use Edit - Move and then uncheck the box for "stretch etch"
  • oldmouldy
    oldmouldy over 10 years ago
    You could use this keyboard alias for the space bar to "drop and pickup" the component during move to refresh the rats displayed:
    Funckey “ “ “pick_to_grid –cursor;pick_to_grid -cursor” # use spacebar to minimise connections
  • GP studio
    Steve thank you, but your suggestion not solve the question.
    Oldmouldy, thank you very much for reply and for informations. Now i have the funckey in the env file. But not work ! Maybe i not understand well the command.
    The connections are minimized only when i pick to end position. When i move the symbol, the connections are attached at start point, using space bar no change are made, only when i pick to the final position, the connections are minimized.
    In pads, cadstar, altium, when move component, the connections are immediately connected to the near point available ! Why not possible in PCB Designer  ? :-((
    Another request, for the Cadence Partner Channel !  Best regards, Gianni.
  • ScottCad
    ScottCad over 10 years ago
    The feature you are after used to be called "RubberBanding" of nets in days of old. I don't believe Allegro has ever had that feature. The older layout tool does have it and it works great. Certainly a good feature request to have implemented in the next cut of Allegro. Scott.
  • GP studio
    GP studio over 9 years ago
    Hi ScottCad,
    thank you very much for your support. It's a great feature for future realeases of OrCAD/Allegro PCB.
    Please Cadence make it possible !
    Regards, Gianni.
