  3. Exporting PDF in Allegro PCB Designer
  • Views 22464
Amano Ger
Amano Ger over 11 years ago
Hi all,
I want to export pdf file from a brd file with hatching format for shapes (left image), but Allegro just allows me to export as blank or solid shapes (right image). Anybody may give me a clue to solve this, thanks all.
I exported pdf with Allegro 16.6 lite  in File -> export -> pdf (for both optional Filled shapes or not).
  • Dhamodharann
    Dhamodharann over 11 years ago
    While you exporting it looks like that. Did you see it in Gerber preview tool.
  • steve
    steve over 11 years ago
    The Filed shapes option works for me so check the exact version of software you are running from Help - About. If it's not 16.6 S047 then go to COS and download the latest hotfix and try again.
  • Amano Ger
    I opened Gerber films  in Cam350, everything was alright and all shapes were solid. But I just want to see shapes as hatch format on a pdf file. Is it possible, right?
    Thanks, sincerely.
  • Amano Ger
    My version is 16.6 P004 and the filled shapes option just gave me solid format for shapes not hatch on pdf file. I will try to update and exporting again, thank Steve.
  • Luc S
    Luc S over 9 years ago
    The PCb Designer Lite cannot export a pdf with the Export-->PDF menu...as it is a lite version
