  3. TCL scripting to get fewer property fields in generated...
  • Views 12990
TCL scripting to get fewer property fields in generated PDF
Pawanshiv
Pawanshiv over 10 years ago
Hi ,
When I generate PDF using TCL scripting there are lots of unwanted property fields in component menu.
Please help me filtering these fields.
I only want to selected fields like
1) Manufacturer part name
2) Package
3) Part refrence
etc.
  • hmkr
    hmkr over 10 years ago
    Following modification in the %CDSROOT%/tools/capture/tclscripts/capUtils/capPdfUtil.tcl file should take care of your need-
    Option 1:- Add the name of all properties in the "lFilteredPropList" that you don't want to display in the generated PDF.
    proc ::capPdfUtil::isFilteredProp { pPropName } {
    set lFilteredPropList {
    "Line Style"
    "Line Width"
    "Color"
    "Location X-Coordinate"
    "Location Y-Coordinate"
    < Add your more properties in this list that you don't want to display in PDF>
    set lSearchIndex [lsearch $lFilteredPropList $pPropName]
    if {$lSearchIndex != -1} {
    unset lSearchIndex
    unset lFilteredPropList
    return 1
    unset lSearchIndex
    return 0
    Option 2:- Alternatively, reverse the code of the function as follows to just make the properties Part Reference and Part Number as the only properties shown in the popup.
    set lUnFilteredPropList {
    "Part Reference"
    "Part Number"
    set lSearchIndex [lsearch $lUnFilteredPropList $pPropName]
    unset lSearchIndex
    return 0
    unset lSearchIndex
    return 1
