  3. Back annotation and reference designators
  • Views 14524
aricbeaver
aricbeaver over 11 years ago
Say I have a 0603 resistor .dra and its reference designator is R*. Now I want to reuse that same .dra for a capacitor. Forward annotation results in the .dra inheriting the schematic reference designator, i.e. C*. Reverse annotation inherits the .dra reference designator.
So, do I have to create two nearly identical .dra's; one with C* and the other with R* for reverse annotation to preserve the prefix from the schematic?
Thanks!
  • oldmouldy
    oldmouldy over 11 years ago
    The Back Annotation will use whatever References are assigned to the saved board file used, so a "netlisted" Rx, Cx, whatever, will be used unless there has been some change to the Reference text, like manual Text Edit, or Logic>Auto Rename Refdes. In any case, the References assigned in the board will be used.
