  3. Snap to grid does not work. (V16.6 P004)
  • Views 13579
JohnnyWalker
JohnnyWalker over 10 years ago
Snap to grid does not work. (V16.6)
Well, kind of. Typically when I drag a component, my cursor snaps to the grid while I’m dragging (mouse button is held). However, it is not, but it snaps when I release the mouse button. Where do I change the setting?
Thanks.
  • JohnnyWalker
    By the way, I opened up another project and that works fine. Therefore, it must be some sort of setting associated with the project.
  • Dhamodharann
    Dhamodharann over 10 years ago
    Currently check the project before you starting. Goto----> setup------> Design parameter---->Grids---->setup grids---->Enter the offset /spacing values as your need. Eg: 5 mils. Use all the values as 5 mils.
  • steve
    steve over 10 years ago
    It's more than likely down to the Active Class / Subclass. If this is set to Etch / Top then that's the grid that items will move on. Check your grid settings then check the Options menu for Active Class and Subclass. If you make this a Package Geometry layer like Assembly Top then the component will move on the Non Etch Grid, if it's Etch / Top then it will move on the TOP grid.
  • fxffxf
    fxffxf over 10 years ago
    You might want to download the current Cadence update to 16.6, P004 indicates that you are using the production release. The current patch version looks like it is s047 and see if that fixes your snap problem. It looks like a snap fix was put into the Cadence s001 patch
