  3. Occurrences reference designator assignment in complex hierarchical...
  • Replies 15
  • Subscribers 167
  • Views 23828
Occurrences reference designator assignment in complex hierarchical design
coronas
coronas over 10 years ago
Hi all,
consider this AN
when he says:
"Note: As a part will have more than one occurrence in a complex hierarchical design, it is essential that all these occurrences have a unique reference designator in the design. For this, the yellow columns for the parts must have unique reference designator. Therefore, for a complex hierarchical design, the preferred mode of annotation is Occurrence. This ensures that each occurrence gets a unique reference designator."
what  does it means?
when in occurrence annotation mode,
1)sub-circuit reference designators change automatically at each hierarchical block placement/copy action
2)user have to change sub-circuit reference designators at each hierarchical block placement/copy action
I'm asking this because maybe I misunderstand and / or I forgot to set something
if I copy a hierarchical block, the reference designator does not change automatically, and I want that it does.
I had some problems also manually change the reference designator in sub-circuits by double click text to open the display properties dialog, changes made in one occurrence affects other occurrences and other weird things ...
the only way is to change the reference designator manually in property editor view.
i'm using Orcad Capture 16.6-S032.
  • oldmouldy
    oldmouldy over 10 years ago
    IF you want the References in Occurrences mode to be "automagically" maintained you MUST set Options>Preferences, Miscellaneous tab and check Automatically Reference Placed Parts AND Design Level, then copying a block will get a new set of references assigned to the parts in the copied block. IF you want to manually edit the References in Occurrences Mode you MUST use Edit Properties to edit the properties, changing visible properties won't work correctly. Tools>Annotate, Unconditional with Occurrences (Preferred) will re-reference the entire design.
  • coronas
    Thanks a lot!
    Design Level checkbox default state were unchecked...
  • EngineerPerson
    EngineerPerson over 9 years ago
    WARNING!  If you netlist a complex hierarchical schematic and layout a PCB, you will be unable to make changes to the schematic after the fact.  From what I can tell, any time you cut and paste a hierarchical block (to move within a schematic page or move to another page, for example), the OCCURRENCE properties (your actual reference designators used during layout) are DELETED and overwritten by a random new reference designator or question mark (depends on the annotation checkbox), and all parts in the hierarchical block are assigned new ID values.  This deletes any correlation to the physical circuit that you have already laid out on the board.  For this reason, and as of 4/8/2016, I do not think that the Cadence software actually supports maintainable and robust complex hierarchical circuit board design.
    Please somebody prove me wrong here, as I'm in the process of undoing 2 months of work on an incredibly complex hierarchical design, to flatten the design, BEFORE we can even start working the layout...  This is a severe disappointment, and has set our project back by months.  I would have preferred it if Cadence just admitted that hierarchical designs are not supported, so that I would not have gone down the path of a complex hierarchical design...
  • Wild
    Wild over 9 years ago
    Jeff,
    I do this type of work all the time, I do nested and reuse models on almost all of my designs.  There are tricks to working with Hierarchical designs and they are fully supported.
    EMA sells a  tool that can help you (Note: I don't use it), you mat want to contact them.
    Bill
  • Wild
    The tool is call Circuitspace.
