  3. i.Mx6 SoloLite, 0.5mm BGA fabrication
  • Subscribers 166
  • Views 12618
PRASH36
PRASH36 over 10 years ago
Hi ,
I am presently working on i.mx6 sololite processor based project which is having 0.5 mm pitch.hence bga breakout is maintained as 3mil tracewidth and 3.33 spacing.
i'll be very much thankful, if anybody can suggest a Fabrication House for this application in India, its getting critical at the moment.
Thanks.
Prashanth
  • GIRISH KUMAR
    GIRISH KUMAR over 10 years ago
    Suggestion : When you work with 0.5mm pitch BGA Package its always ideal to go with VIP & HDI technology . It will solve many issue related to fabrication & assembly caused by the standard design PCB design rule. Make use of gloss->add fillet to strengthen the breakout contact
  • PRASH36
    Thank you for your valuable Suggestion
    Regards
    Prashanth
