  3. unplated holes
  • Subscribers 166
  • Views 15316
unplated holes
shangwu
shangwu over 10 years ago
As a common practice in OrCAD PCB Editor, I create the unplated hole by putting a small pad that is smaller than the drill size, so it will be drilled away.  The problem is, the DFM checking software from PCB companies always complains about that and cause a lot of time wasted in communication.  Is there a way to create an unplated hole without any pad on it?
Thanks.
  • redwire
    redwire over 10 years ago
    Yes.  Mechanical pin.  Choose unplated hole in the padstack.  Most fabricators like a "target" pad (say 4 mils, for a 20+ mil drill).  Maybe some of the discount houses can only deal with a drill with no target pad?  Both methods work...
  • SevenFortyOneB
    SevenFortyOneB over 10 years ago
    Fabricators will usually use their CAM software to remove the "target" pads as one of the first things they do when prepping a job.  I'm not sure why they would complain about it as the removal is automatic and takes a few seconds to do.  If you want to create padstacks with target pads, consider adding a print note allowing/instructing the fabricator to remove pads that are smaller than and NPT holes.
    You can create a NPT pad stack with no "target" pads.  Leave begin, default internal, and end layer regular pads and thermal relief set to null and just define anti pads and solder mask clearances for the pad stack.  You can then place it as a mechanical pin in a symbol.
