  3. PDF file export with drill hole open & etch filled(not lining...
  • Views 2273
PDF file export with drill hole open & etch filled(not lining)
Vikas Dabas
Vikas Dabas over 11 years ago
My requirement is drill hole open.
It is solved by a nice guy but one problem is still remains,
Ploting pdf has etch hatched/ lines filled not solid filled. can you tell me...
I have also tried exporting pdf, it is showing filled shape but the color is gray.
Please suggest something.
Vikas Dabas
  • oldmouldy
    oldmouldy over 11 years ago
    You could try getting the "Prototype Plotter" App from the Capture Marketplace, that will get you "black" artwork with open drill holes and then make a PDF from that output.
  • Vikas Dabas
    please help me install nsware, i tried to place it in every folder but din't succeded
    it not getting to be shown in allegro............
    This issue is solved but the printing is still etch lining not etch filled.
    The etch must be solid black rather than lining...
  • Vikas Dabas
    Please someone ans the problem.
    otherwise i loose half of what i've gained till now.
    Why plot (pdf printing) printing etch in lining not filled. And second the pdf export option has no drill opens and etch in gray color.
    It is needed for making single side board
