  3. "Thru Pin to Thru Via Spacing" Error?
  • Replies 7
  • Subscribers 166
  • Views 7776
Hossein1357
Hossein1357 over 10 years ago
I read somewhere that using spacer holes like below is a wise way.
I am trying to put some via around the pad of my spacer footprint. However, I receive DRC errors (Thru Pin to Thru Via Spacing) when I place some via on my big pad
How can I create a symbol like above picture?
Hossein
  • steve
    steve over 10 years ago
    difficult to see what your actual issue is ? Can you be more specific ?
  • Hossein1357
    I know it is a long time since the last post of thread. Anyway, I wanted to make an update for you.
    I was making a mistake. First, I had used a pad as connect pin - not  mechanical - and I was trying to place Top & Bottom circles - according to the application note - on this pad!. which caused doubling on Top & Bottom Etch!. After careful reading of App note, I tried again and then it worked. I appreciate your great help and support steve
    Thanks again,
    Hossein
