  3. Connecting between two pins in a single package. (without...
  • Subscribers 166
  • Views 786
Connecting between two pins in a single package. (without schematic!)(Simple one)
blueberritic
blueberritic over 10 years ago
I'm using OrCAD PCB Designer version 16.6.
And I'm designing a very simple and small PCB to connect between two electronic parts.
So I created a PCB without using schematics from OrCAD capture.
Everything was fine until I try to short two pins (pin # 5 & 14) in a single package (fig below).
Is there any solution for this problem?
(Since my major is not electrical engineering and I just installed OrCAD on my laptop a week ago firstly in my lifetime, I beg you for detailed instructions)
  • steve
    steve over 10 years ago
    However you made the connections in the first place repeat this process so that these two pins are joined together with a ratsnest. Remember the tools are front end driven and ideally require a schematic to sort out the connections properly.
