  3. duplicate drill hole?
  • Replies 8
  • Subscribers 166
  • Views 17049
Jorisss
Jorisss over 10 years ago
Hi All,
I have a question. Where can I find documentation for duplicate drill hole?
I used this link but that did not work: community.cadence.com/.../what-s-good-about-allegro-dfm-drc-updates-16-5-has-a-few-new-enhancements
Joris
  • steve
    steve over 10 years ago
    There is a solution on Cadence Online Support. Once you click on the link you will need to login using your COS account:- http://support.cadence.com/wps/myportal/cos/!ut/p/a0/Dcc7EoIwEADQs1ikxEQlIDIUfgpLZ7RQGmdJNmEHSDCJen193eMtv_PWwYcsJPIOxv8fGnEeyQ0TuZ32qo5BNd-5fjW3AOTIWSauNJLyLruAGsBidvAQ9PPosxNGso6JOHerQjKBmpIPTBiE9A4YmdBBLfs0jXVECKo_Q-wbI0xX6KrcViBwjWi0lMqU-Qo3hZCQ83nYL34wdHa9/
  • Jorisss
    thank you, when i do this:
    can this give me a DRC?
    Joris
  • steve
    There is no screenshot so please describe "this" ??
  • Jorisss
    can you see it now?
    or or nl.tinypic.com/r/50it0h/8
  • steve
    No the x and y locations of the drill holes must be the same for this DRC to work. You would be better using the same net DRC thru via to thru via. Enable this in setup - constraints - modes - same net spacing modes, turn them on and then in Constraint Manager - Same Net Spacing - Options
