  3. Special component
  • Subscribers 166
  • Views 12781
Special component
andmei
andmei over 10 years ago
I have to crate a new package in OrCad PCB. It consists of two thruhole pins,
like a wired resitor. Instead of mounting a component there is only a piece of
copper on the etch top layer.
When I create this I get a drc error at the position where the etch top layer
overlap the thruhole pin.
How can I create such a structur without getting a drc error.
Thanks for you help.
andi
  • steve
    steve over 10 years ago
    Edit - Properties then select the Pin and add a property NET_SHORT with a value of netname1:netname2 etc. This is a way to create a valid shorting component. There's a note on this :-http://www.parallel-systems.co.uk/images/PDF/Netshort_Definition.pdf
