  3. How to remove individual group member
  • Subscribers 163
  • Views 19056
Allan M
Allan M over 11 years ago
Hi Everyone!
I am using OrCAD PCB Editor 16.6.  Say I have a group of elements named "Power Supply" or some other moniker and I wish to remove a single member of that group, perhaps a capacitor.  So far, the only way I could find to remove that member is to disband the whole group and redefine a new group minus the unwanted capacitor.
How can I remove a single member from a group without disbanding?
Thanks in advance,
Allan Macdonald
  • Randy R
    Randy R over 11 years ago
    Edit->Groups, then select the group you want to remove an element from (Group highlights)
    Set your find filter to the element type you want to remove, press and hold the CTRL key, and click on the element (element is removed from the group and should dehighlight)
  • Allan M
    Thanks Randy.  That worked!
    Cheers,
    Allan
